mydazeoff
Sep 15, 2017Explorer
Assuming your frig is in a slideout then there should be a thermostat behind the upper grill entry. It is attached to the cooling fins. You can test for power at this point. Since temp. Is cooler the fan cooling may not be turning on. Modified vent or adding a fan that operates at lower temperatures might be necessary to get your refrigerator temp down. Several good mods on YouTube.com.
