dougrainer
Oct 31, 2015Nomad
WonderingWoman wrote:
Well we took it to the dealer and it was the thermostat. And with our unit you can run off of shore power with no battery on gas or electric.
You are confusing Battery with shore power. IT TAKES 12 VOLTS TO OPERATE YOUR REFER. The shore power supplies 120 to your POWER CONVERTER and THAT supplies 12 volts to the refer. You do not have to have a battery connected, but you NEED a battery to help regulate the Power output from the converter. Doug
