dougrainer
May 11, 2023Nomad
A Fan motor locked or has bad capacitors will NOT lug a Genset down. BUT, you have replaced those items. That should point you to another source of your problem. A Locked compressor will. I think your compressor is trying to start even tho you state fan only is selected. AND if this is the case, then you replace the complete upper AC unit. Doug
