COboondocker's avatar
COboondocker
Dometic Fridge not working...again
We had problems with our dometic fridge and the pilot getting blown out while driving. Our dealer fixed it under warranty (it's still only 8 months old and has never worked properly.) It wasn't cooling properly and they fixed that as well saying there was some insulation in the wrong place. We took it out camping for the first time since the fix and it didn't work. Running on LP, haven't checked 110 since the repair. After one day the fridge was 68 degrees inside. It was in the 20's overnight and highs in the low 50's. The dealer told us not to run the fridge on the coldest setting because it would freeze up and stop working. We tried the 1st (warmest) and 2nd setting to no avail. We were PERFECTLY level just to make sure that wouldn't be an issue. Is this normal? Do we have a lemon? Should I be taking a brand new fridge back the dealer for a 4th time in 8 months or ask for a replacement?
  • RAS43's avatar
    RAS43
    Explorer III
    I would find a Dometic dealer and have them troubleshoot it since the RV dealer can't fix it.
  • The admin for this forum deleted the part of my thread that called your dealer/TECH a derogatory name. I stand by what I stated. DO NOT GO BACK TO THAT DEALER. They are not qualified to fix your problem. The problem you have is simple but the fix and who pays will be complicated. From your post, the OEM (NOT Dometic) did not install the refer and cabinet to specs(insulation not secured). So, Dometic will probably pay for a new cooling unit, but the modifications to the cabinet and insulation and adding a 12 volt fan will go back to the OEM maker of your Camper. Dometic is not responsible for anything other than the actual refer. You need to contac the OEM maker of your camper and ask if they will pay for another shop to fix your refer correctly. Doug
  • Was the fire burning all the time it was not cooling properly, you didn't say.
    And you're just thinking that the dealer didn't do the insulation correctly ?
    Isn't it possible that the dealer fixed what they obviously seen was a problem, and that if you took it back, they would now know the cooling system is the problem, and replace the fridge ? But if you have a closer authorized warranty station, do it.
  • adambeck7 wrote:
    old-biscuit - pretty sure it's the DM2862RB
    doug - thanks for all that.
    since it's a new fridge do i need to take it back to the dealer where we bought the truck camper or could i go anywhere that does dometic warranty work? getting a little frustrated driving 40 min each way for work that doesn't fix the problem. i don't want to do too much myself for fear of the dealer then saying that i caused the problem. thanks for the help everyone.
    First off...........
    EVERYTHING DOUG posted is right on the mark!!!!!!
    He has over 35 yrs. RV TECH SERVICE
    YOUR Dometic fridge cooling unit has been damaged due to the insulation falling down and blocking draft air flow. That has resulted in overheating of cooling unit (as evidenced by high food compartment temps) Overheating cases crystals to form, plate out on inside of tubing causing blockage which cause more overheating more crystals more blockage ......damage is accumulative and permanent.
    You need to contact MFG. Representative, Dometic Representative and fight your case for replacement. You will never get satisfactory results with that current fridge.
    HERE is Installation Manual.
    Print it out so you have a copy to use in your discussions.
    Dometic provides the instructions to RV mfg.
    RV MFG. are suppose to follow those instructions.....not doing so results in poor fridge cooling. RV mfg. causes....NOT Dometic Fridge
    Get ALL parties involved with you ...........!!!!
    Good luck. Get that damaged fridge replaced.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
