Fisherguy's avatar
Fisherguy
Dometic fridge WITHOUT thermostat
My bud's 2013 trailer has a Domeic 8 cubic foot fridge without a thermostat, it's labeled as having an "Automatic refrigerator temperature control"" but it doesn't seem like a very good idea to me, the fridge kept freezing stuff while we had it out for last week.
Also, when this particular model is running on propane there's no light at all on the top panel; I'd expect it to at least have the AUTO and/or PROPANE lights lit up similar to the last 2 trailers I've owned, 1 had a Dometic, the other a Norcold.
Has anyone run across a Dometic like this? (Don't know the exact model number)
  • He is saying when you are set to propane only there are no lights.
    It only turns orange when propane fails to light.
  • Old-Biscuit wrote:
    The Auto Temp Control DOES have a thermostat and thermistor....just doesn't have Temp Setting Adjustments
    The Thermistor (Temp sensor) attached to FIN can be moved to adjust overall fridge temps
    Move thermistor UP for colder
    Move thermistor DOWN for less cold
    In your 'friends' case....DOWN
    In AUTO the fridge controls will select AC Power (Priority)
    If AC Power becomes unavailable the fridge swaps to GAS
    It will swap back to AC when AC Power is restored
    If you select GAS Manually the fridge will only run on GAS ...no swapping back to AC Power
    CHECK Light comes ON when GAS Fails to light off and prove a flame is present.
    Several Dometic Models use the Auto Temp Control
    This Manual covers some of them
    OK Thanks, I didn't know about the thermistor on the fin, will see if he does.
    I do know how the "auto", gas, AC thing works though, but what I'm saying is none of the indicators light up like it your pic, that I've never seen before.
    (... and this is regarding my 'friends' trailer BTW, mine has a Norcold with a thermostat and working indicator lights)
    trailrider wrote:
    You can get one of these eyebrow boards that has the adjustable temperature. It is a direct replacement.
    Thanks, I think I can barely make out that part number.
  • You can get one of these eyebrow boards that has the adjustable temperature. It is a direct replacement.
  • The Auto Temp Control DOES have a thermostat and thermistor....just doesn't have Temp Setting Adjustments
