Tom_M wrote:
It looks like you haven't checked the filter as dougrainer suggested. A few years ago a fellow camper was almost to the point of replacing his fridge but luckily he checked the propane line. It was full of oil.
Bingo, I was going to mention this. Usually, when I had this type weird problem I would hook the Shop LP tank to the refer and bypass the RV LP system to see if it worked correctly. Have you actually verified the refer operates to temp on 120 volt? What were the lower temp? Below 50 degrees? Me thinks the Flame is at correct HEATING height. Because the refer is warm inside, you cannot get the Flame to go to bypass mode?. By getting the refer to temp on 120, then start on LP and watch the flame when you open the refer door to allow hot air inside. Once the Capillary tube on the fins starts to warm up, the Bypass flame will then get larger to show the tstat and LP system is doing its job. Last, when ON LP, how cold does the refer actually get? Doug
PS how large LP tank does the RV have and when was the last time it was either purged and filled or just filled?
