dougrainer
May 17, 2022Nomad
It is a hell of a lot cheaper to replace the ECO/Tstat kit, than a Circuit board. Unless you are checking for 12 volts thru both the ECO and Tstat when the malfunction occurs. Now, you don't state year model. Atwood/Dometic from a few years ago from about 2018 to 2020 had defective Circuit Boards, that were changed out under the warranty period. Intermittant operation was the problem. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
