dougrainer
Apr 10, 2022Nomad
Other than the Fail code, have you seen abnormal icing on the fins? I would not throw away a good functioning refer just because a defrost element has failed. Even with the Fail code, the refer should still be functioning. Doug
This is what I have replaced over the years as the most common defrost failure. It may be able to be used in place of the discontinued part. Just have to modify how it is installed.
https://rvpartsexpress.com/product/dometic-3851411011-heating-element-water-drain/
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
