dgreen1069's avatar
dgreen1069
Dometic NDA1402 Cooling Fin Heating Element
My rig has a Dometic NDA1402 refrigerator. When I turned the fridge on this afternoon I got error code 12. According to the service manual, error code 12 means there is a problem with the refrigerator side cooling fin heater element. I checked the element with a multimeterand found an open circuit (no resistance). I should be seeing 3 to 4ohms. Long story short, I have determined it needs to be replaced.
Looking online, it appears the part (3850674015) is discontinued and unavailable everywhere I have looked. I would HATE to replace the entire fridge for this one simple part. Has anyone else run into this problem? Can I use a different heater element to accomplish the same task and fool the fridge into working?
Does anyone know if I could simply add a jumper in place of the heating element to trick the refrigerator into working? If this is a bad idea or dangerous, please let me know. I am just brain storming at this point.
  • The rig in your signature says 03, I would say the frig could use some help.
    In my 07 the frig (norcold) up and died while on a trip. I also did not want to really replace the frig. I did however looks at replacing with residential ones. To much wood work for my to make it look like it belonged so that was out. A new norcold same size would mean taking the windshield out to get the frig in. So that was out.
    I ended up going with new cooling unit from JC Refrigeration. https://jc-refrigeration.com/
    I changed my old cooling unit for their 120v only unit as I do not boondock and am alway plugged in.
    I am very happy with the unit and JC customer support is spot on great folks to work with.
    Good Luck
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
