dougrainer
Aug 27, 2020Nomad
Gkaiser wrote:
Freezer is cold enough to freeze the milk i put in there to keep it cold.
Replaced thermistor - now retesting.
Also checked voltage at board for heating element and sill getting low voltage with new board.
Could eyebrow board be bad also and not signaling the main board to go electric?
So 2 problems 1 fridge isn't cooling and 2 it only works as gas. Either in gas only or auto mode. It goes to gas.
The Operating temp of a freezer is 0 to 10 degrees. Milk will freeze at about 30 degrees. So, using the COLD temp of your freezer by gauging the milk freezing without an actual temp is not the way to go. If you want, continue throwing parts and spending money. OR YOU COULD DO WHAT I TOLD YOU. HOT WIRE THE 120 ELEMENT FOR 24 HOURS AND SAVE SOME MONEY. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
