Gjac
Aug 29, 2020Explorer III
You have gotten good advice so far the only thing I would add to help your issue is to check the connection from the eye brow to your control board. When mine would not switch I cleaned the contacts with an eraser on the board and it allow the eyebrow switch to work again. Also is rust from your flue blocking the slots on your burner tube when on propane or are the slots rusted out causing a poor flame?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
