dougrainer
Sep 01, 2020Nomad
Gkaiser wrote:
Replaced Eyebrow Board. Fridge now works on electric, and the temp this morning was 30deg. so now it's over cooling. just needs the thermistor adjusted down to dial in a good temp.
So all problems fixed. seems like it was just the power switch all along, but now it has all new circuitry top to bottom. ~$180 total on amazon.
Model is a DM2852RBX
Well, you have not followed the advice. Good to know that the CU is good. You should have the Auto Temp model. You slide the Thermister up and down on the fin to change the set temp. It is usually about 4 degrees. NOW, IF you had followed my advice, you could have spent your money better. You could have purchased the eyebrow, with the adjustable 5 position Temp, and your refer would NOT be a AUTO temp refer. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
