I have a 2005 Mandalay with a Dometic refer, model NDR1292. During colder temps outside my refer turns off. Once the outside temps gets back into the higher 50s or 60 d range, the refer turns on. I d...
Thanks for your response, I called Dometic a couple of days ago and they were absolutely no help whatsoever. Useless!!! The problem does seem rare but you would think Dometic could look into it. Our refer has been out for two days but just turned back on since it has turned sunny and in the 60s. I have a mobile RV repairman coming over today for another problem and will ask his advice/suggestions. If I can get a fix I will post it here.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
