Johno02
Oct 06, 2013Explorer
Not the exact problem, but if the refrig inside temp is too cold, it will not work. Solution was to turn on coach heat, with refrig door open and let it warm up a bit. Then it worked OK from then on. Seems like the inside refrig thermostat thinks it is cold enough. Once started, temps in freezer started dropping as they should, and all was well.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
