bersh wrote:
The flu & chimney were cleaned, as was the burner area. I haven't checked the LP pressure at the fridge but the stove, furnace, and hot water heater all operate correctly and if the pressure is low I would think it would affect them. I'll have to get a test gauge and take a look though.
I have a new refer(6 months old) at the shop right now and customer complaint was no work on lp. I tested the LP pressure and it was 9.4 inches W/C. SHOULD be 11.5 no load. The refer would NOT even chill the freezer at that low pressure in 90 degree heat. Yes, the other LP appliances fired up. The regulator was bad and would fluctuate the LP pressure from 7 to 9.5 while the refer was running. Doug
