Old-Biscuit
Sep 08, 2014Explorer III
In order to remove 'pins' you need to remove hinge. In order to remove hinge you have to remove fridge (needs to slide out into rv enough to get to one of the hinge mounting screws that is installed from the side)
HERE is an exploded view of fridge
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
