mkletka's avatar
mkletka
Dometic RM3663 problem
My refrigerator worked fine last year but not this year. My upper control lights do not work. I've checked the heating element and that is within range. I am getting 120 power to the lower circuit board. I'm not sure which terminals on the lower circuit board I should be testing to see if there is power going to the upper circuit board. I see mention of a PAL tester from Dometic but don't really want to spend $100 for one of those. I suspect that either the wires from the lower board to the upper are damaged or the upper board is no good. Does anyone know which terminals on the lower board should be tested to see if power goes to the upper?
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
