joe_blow's avatar
joe_blow
Dometic RM3862 question
Hi,
I rebuilt the fridge about 4 years ago with an arctic cold ammonia coil and it has been working great.
Prior to I installed a dinosaur electronics board which is still solid.
The other day I noticed my fridge would not run on GAS (propane) so I disassembled it. I called Dinosaur electronics to see if perhaps they thought I might need a board and for diagnostic tips.
I came to the conclusion the brass gas valve was not working properly. I removed it to clean the jet and I sprayed some brake kleen in to the valve and put 12v power to it to cycle the valve repeatedly.
I put it back together and it worked. Since then I ordered a new valve but am leaving Sunday on a trip and hope it works the duration.
Questions:
Has anyone experienced something similar ?
What purpose does the small foam plug serve that is in the inlet valve orifice....diffuser?
Thanks
Joe
  • If I understand what your referring to correctly, that metallic foam core in the orifice is a filter to keep the tiny little hole from plugging.
    I’ve never had a problem with the gas valve on mine. Is the solenoid working? Can you hear it click when you turn it to gas?
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 22, 2025
