MySuncoastRV
Aug 29, 2018Explorer
If you are getting the initial flame then you know the gas valve is opening as commanded. It sounds like the thermocouple is your issue. Remove the cover and look for deposit buildup. Scrape it clean if anything is visible. You can also bend it very slightly putting it closer to the flame. A failing or dirty thermocouple will give a false reading which will simulate a flameout therefore commanding the gas valve to shut off. Please post your results.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
