dougrainer
Aug 30, 2018Nomad
bentSpaceTime wrote:dougrainer wrote:
YES. You will be surprised at how dirty the burner area will be with rust and flaking paint and such. IF you have access to a compressor, blow out the flue above the burner, to remove build up on the Spiral baffle INSIDE the flue tube. I rarely remove the burner, I clean out with a small brush and compressed air from the shop compressor. Then vacumm up the debris. Doug
Cool! So, not necessary to remove the burner housing, if I do it that way?
yes.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
