Rudyp's avatar
Rudyp
Dometic toilet 310 model leak
I have a question and hope to find an answer, and thank you all ahead of time. Our tolet is a 2 piece porcelin bowl and it leaks fluid between the upper bowl and base in the middle where they are connected.. thank you all kindly,
Rudy
  • There's a seal in between there and the bolts can loosen up. Unfortunately in order to tighten it up you need to remove the toilet and turn it upside down. The manual posted previously will tell you how.
  • Here is the manual for your toilet...this should help.
    310 Manual....HERE
    It does say:
    "Factory-sealed bowl-to-base as-
    sembly –
    Unlike other Dometic foot-
    pedal toilets,
    the bowl and base of
    310 and 320 series toilets should
    not be separated for any reason
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
