Dutch_12078
Sep 30, 2018Explorer III
Wax rings are not recommended. The normal RV vibrations while in motion can displace the wax enough to cause a leak. The correct foam gaskets are readily available and inexpensive. I would only use a wax ring as a temporary fix until a proper gasket was obtained.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
