Micro1706
Aug 02, 2016Explorer
Hi Chris
Thank you so much for taking the time to further explain this. We felt this was the case. We had read and re-read your previous post regarding this subject, and finally felt we should order the Duo Therm model you mention. It should be arriving in the next day.
As for installation, I have determined that indeed the a/c model on this tt is a Brisk Air II.
A friend who is an electrician has agreed to go up on the roof and do the install. He is not a "certified a/c tech" so I am just wondering if it is ok to have him do the install? From what I have read from other folks who were faced with the same issue and installed either the dometic or supco hsk, it seems the install is pretty straightforward.
Any advice or suggestions for the install would be greatly appreciated. I have seen the pdf from d.therm with install instructions, and I am hoping the connections mentioned are applicable to what is evident on the BA II.
Thanks again for all your time and consideration in helping us understand this.
All the best
Bob
All the best
Bob
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
