Chris_Bryant
Aug 04, 2016Explorer II
stevenal wrote:
According to the spec sheet, it uses an 88-106 uF cap; same as the 6E.
That should work fine, even though they don't rate it for that large a compressor. The last one I had my hands on was 43-52 uf.
It's tough to figure Supco specs though, as they change often. See http://www.supco.com/eclass.htm - the table, which gives different voltages, as well as the last one I installed-
Note the voltages.
All of that said, if it really is 88-108uf it should work quite well.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
