- lanerdExplorer IIWell, I ordered the fumoto valve with the nipple. I use distilled water in my cpap and typically buy 1 gallon containers of it at walmart. So, I'm thinking that instead of recycling the empty plastic water container, I can use them to put the used oil in. With the valve and a plastic tube, this should be an easy job. One gallon containers aren't that heavy and easy to move around...plus each will have a cap!
Whatcha think?
Ron - DougEExplorerTry your local farm feed store. They have a number of large feed pans that might work.
- Dave_H_MExplorer II
lanerd wrote:
Dave H M wrote:
or a drain valve - like Futimo
I think you mean Fumoto..right? In any case, do you remember the correct drain hole size?
thanks
Ron
Well at least I started it with an F and ended it with an o. :S
I don't recall drain plug sizes. I had a power stroke, but now have nothing but gassers. - patperry2766Explorer IIwheel kit
About once a month the local full service car wash sells all their empty drums for $5.00 each. You could cut one down and put some wheels on it to make it easier to move. - pkunkExplorer
Too Tall wrote:
Do MH's ever have a line off the bottom of the pan? Engines in boats have them so you can use a 12vdc or AC pump to drain and fill. Makes life easy.
Not from the factory, but a Fumoto valve can be installed. I put mine on with a full crankcase bu using a shopvac to hold the oil up while replacing drain plug with Fumoto. The Fumoto with the nipple that you can put a clear hose on make it easy to drain into gal. containers. - Too_TallExplorerDo MH's ever have a line off the bottom of the pan? Engines in boats have them so you can use a 12vdc or AC pump to drain and fill. Makes life easy.
- l001952119Explorer
lanerd wrote:
My Cummins ILS holds 28 quarts of oil (7 gallons). The largest container I can find that is used to drain the old oil into is only 5 gallons. What do others use so that you don't have to use two containers?
Ron
I assume you mean draining the oil directly from the crankcase into a container? If so, NAPA has a 56 quart oil drain pan with a spout for emptying. Must be ordered from catalog. My prior truck had a 38 quart capacity. After draining into the 56 qt. pan, I poured the oil, via a large truck funnel, into two five gallon gas cans and emptied them at Wal-Mart. They have a five gallon limit, but once they know you, ten gallons can usually be dumped! - badboy368Exploreri use a plastic 55gal. drum cut down to about 14inches and just slide it under the coach drain oil then put into the empty containers.. works great and it was free:):C
- AcampingwewillgExplorer III use the fumoto and I have one of the Drain Pan's you can buy at any diesel truck part store, its on wheels and rolls easily under the coach for my 32 quarts. I do as others by drilling a hole in the old filter before removing, makes it much easier to handle. Now, with all this good, there is some bad, I generally pour the used oil back into the empty 1 gallon containers to take to recycling. Its somewhat of a hassle but I've been doing this for 10+ years.
Oh, I think the drain pan on wheels will hold about 80 gallons...they do have different sizes as it gets heavy fast. - Jim-LindaExplorer III do it the hard way with the Cat, 32 qts. Go to Speedco, complete service, don't have to mess with waste oil, documented service for later.
Jim
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
