riggsp
Nov 14, 2014Explorer
Used to drill P.C. boards years ago with a Dremel mounted in a small bench top drill press (that way the holes were straight), and there was less chance of the drill wandering...I don't think you'll need a carbide bit, but you will need a premium quality bit not a wallyworld special. A good bit will be sharpened properly and do a better job...I've seen cheap bits (especially small ones) that were "sharpened" backwards and tore or wore the material instead of cutting.
