Gdetrailer
Nov 14, 2014Explorer III
MEXICOWANDERER wrote:
I am presently using small perforated breadboards that occasionally need the perforations enlarged for leads of larger devices such as diodes and resistors.
Do I really need carbide drills and an expensive Dremel or Skil tool (which in themselves are clumsy to handle)?
And is there a superior grade of hookup wire? I would prefer wire that it extremely soft annealed and easier to strip. I could also profit from expert advice on wire wrapping tools and accessories.
I cannot find circuits online for my rig so I am manufacturing them from scratch.
Get a Dremel DRILL PRESS ADAPTER/STAND.
SEE HERE
That is what my Tech School used when I was there many moons ago, as one of our lab projects we had to design and layout our own circuit board. Once the board had gone through the stripping process we had to drill out the holes for the components. A Dremel mounted in a drill press adapter stand did the trick.
No special drill bit needed unless you want it to last longer since circuit board material is phenolic board or fiberglass. You just need a set of small drill bits which will fit the collet of your rotary tool and will still make a hole big enough for the wire to pass.
If you are considering making your own circuit board from scratch you can find free software for that purpose online or use MS Paint or Photoshop to draw lines and such.
Once you have the design you can flip the design electronically then print it out on a laser printer.
Once you have the printout you place the printed side of the paper on the copper side of the board. Then use a iron you would use to iron clothes placing it on the back of the paper. The heat of the iron will melt the laser toner and as you press the paper and board together the toner transfers to the copper.
Remove the iron then allow board to cool off to room temp.
Once at room temp place the board into warm water and allow to soak, the soaking is important, you want the paper to rub off away from the toner..
The toner acts like a mask and will stop the etching acid from touching what is under it.
I have used the toner method to create and transfer custom lettering to brass and even plexiglas. It does take some experimentation with paper, types of toner and even how much and how long to heat the item for best transfers.. I have even been able to transfer COLOR laser printing..
Once paper has been removed and you have black mask of toner you simply want to inspect and correct any places the the toner did not stick to (they make masking pens for this).
Once mask is OK you then proceed to etching the board.
For an etch ant you can use Muratic acid instead of buying regular etching acid.
Here is a top notch must read if you want to get all the details on the home transfer and etching process.
Click HERE
As for wiring, I prefer to use stranded when possible, bends easier than solid.
I stay away from the old school wire wrap.. Used to cringe every time I had to repair a 60s-70s Sylvania TV which often made extensive use of wire wrapping :M , just a joy to find that one blasted bad connection under several wraps on one post.. Often ended up soldering each post until the bad one was found.
