LScamper
Nov 15, 2014Explorer
For small hand held hole enlarging the Dremel bit set that Gdetrailer points to is fine. The carbide bits used for mass PC board drilling are much sharper but are brittle and may break if not careful.
If you are coating the boards remember that will make it very hard to repair!
If using wire wrap don't try to make it neat. Short straight routing, called rats nest, is best to keep cross talk down.
