mosseater
Jun 10, 2018Explorer II
The goal here is to have the same music outside as in without having a hardwired exterior speaker, so I'm not looking to use my phone as the source.
Do I understand correctly that this should be plugged into an output from the radio and it generates a bluetooth signal from that? Does it need powered from a separate source? The only outputs on the radio are wired-in left and right RCA connectors. Would this unit be plugged into that using an adapter?
