JimK-NY
Sep 19, 2021Explorer II
I would not want to tackle changing the main valve and an additional flow restrictor seems the best solution. Certainly it is simple and beats having a plumber do the work.
You might want to look at replacing the shower head but the Oxygenics is not the way I would go. Look at the specs. It is designed to operate with a flow of at least 1 gallon/minute. When water conservation is needed I do an entire shower with 1 gallon. Good luck trying to get by with less than 3-5 gallons for a shower with the Oxygenics.
