Best I can confirm you have heard from 6 with 5ers, 3 with TT, 1 with a popup, a TC, and a Class C; and 6 with MHs... 2 of which are older ones. My point is only 4 have energy hog MHs... even if they have an absorption refer. For all of the rest a residential refer would be a high part of their energy needs...NOT SO with a big MH. Even with a big house battery bank you will need to run the generator 2+ hours/day or have 600W+ of solar in the West and 1000W+ in the East.
I should have gone residential when my cooling unit went out even though we boondock often. My EnergyStar Whirlpool 21 cu ft draws 7.4 amps at 13V DC and 8 at 12V... less than a 100W bulb with a duty cycle of less than half the time.
Before going residential I had to run my generator 1.5-2.5 hours/day even with 250W of solar so I added a new 500 AH battery bank with it's own 1000W PSW inverter, 100A charger, and a transfer switch for the refer and my Sat receiver/DVR/TV. I can go two days before the refer batteries need recharging without any solar which is close to twice as long as the 800AH on the house side can go with some solar. In hind sight two batteries would have been enough. I turn the refer's inverter off when I go to bed even though it's only 0.2 amps in standby. In the morning I usually run the generator to cook breakfast and power the refer up. If I need ice I turn it on when on generator.
Here is some more info on my going residential and a link to my DIY install. Reread John & Angela post above as it's more real world than a post from someone with a popup.
If you had posted this in the Class A section you would have gotten much better answers since you a looking for a Class A.
A residential refer is another one of those items that once you've had one you'll NEVER go back.
