Redterpos3
Mar 28, 2015Explorer
Dual 30 amp rv's?
Was doing some "window" shopping on Camping World site, and saw a dogbone for dual 30 amp to a single 50 amp receptacle. Are there actually RV's that have 2 30 amp hookups??
CA Traveler wrote:
John,
The typical use of the dual 30A male to 50A female is on a 30A pedestal with a 20A plug and it's the 20A plug that is usually GFI protected. The GFI plug will trip and not work with this adapter.
Golden_HVAC wrote:I do not doubt you. But we traveled 7k miles last year from Indiana to Oregon and back and never saw a 30amp or 50 amp GFI protected receptacle in any campground. In fact I have not seen either in a campground in the last 14 years any where. Not saying they may not be out there though.
Hi,
I think that what you saw was a pair of 30 amp plugs going into a 50 amp receptacle. While it might work in some situations, modern RV parks use GFI receptacles, and will not work with that adapter.
You might find a few RV parks with a pair of 30 amp receptacles at a RV site, however it would be a 'pair' of campsites sharing a single power post, with two 30 amp plugs - 1 for each RV. SO if the neighbor's site is filled, they will use on, and you will only be able to use one of the plugs, and not this adapter.
Any 20 amp GFI that you plug this adapter into will trip, because all of the power going out on the 'hot' line is not returning on the 'neutral' line.
At first I was thinking that you saw a used RV with twin power cords. While that is possible, the past owner might have installed 'anything' - but RIVA will not allow two power cords on one RV, so it was not installed at the factory that way.
Good luck!
Fred.
greenrvgreen wrote:I installed an auxillary 20A circuit in my 50A rig. It can plug into the engine block heater circuit which is a dedicated 20A circuit or it can be plugged into a CG pedestal when the CG is 30A.
I have a 30-amp trailer and I added an auxillary 20-amp inlet, along with a discrete run of wire feeding 20-amp GFCI outlets placed near to major items that I may want to plug in.
I use this when my main source of shore power is rather weaker than the 30-amp capacity, and/or I wish to exceed the available capacity, even at a full 30 amps. I can feed the aux inlet from a generator or from a second, separate shore power source.
I don't use this aux inlet very often, but when I need it it really saves the day. Even if my next RV has a 50 amp service, I will still add an aux inlet and power bus, just to have the option of a secondary (concurrent) power source.
