Artum_Snowbird
Sep 30, 2018Explorer
I would bet you are not getting charged properly, assuming the batteries are OK.
Do a few voltage checks to see what might be.
Check the unit batteries with nothing connected:
Check the unit batteries with the engine running:
Check the unit batteries with the unit plugged in to shore power:
Check the converter output right on the converter itself to see what the converter is putting out:
Check the vehicle battery when off:
Check the vehicle battery when running engine:
Most likely, there is a very loose wire somewhere, and while you think the unit should be fully charged, you have a loose connection and the charge voltage is just causing a loose connection to heat up.
In my case, everything was like you said, but I found the negative wire at the converter negative terminal to the battery was so loose it was barely connected. It had heated up and melted a bit of insulation, would not charge the batteries and worked fine with a couple of turns on the screw head.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
