Sam_Spade
Oct 01, 2018Explorer
shane102.sc wrote:
another test result:
Not sure you have done the ONE test that needs to be done yet.
With everything connected and truck running, measure truck battery.
IF it is above 14 volts but the camper batteries are below 13, then the wiring from truck to camper is NOT right.....or a "battery solenoid" intended to connect the two when the engine is running is not working right.
Battery solenoids are a common point of failure on almost all types or RVs.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
