MrWizard
Oct 01, 2018Moderator
there is point that I have NOT seen mentioned
'REVERSE POLARITY'
the camper lights (incadescent) will work no matter if polarity is correct or backwards
water pump and fridge must be correct
but the converter wires or truck wires, might be reverse
there is a heavy drain (not found) or a reverse charging going on
you have done everything except
things like use a portable charger to charge the batteries and test camper wiring
do they batteries go down IF not connected to the truck
yes, camper side wiring
NO, then its the truck side wiring
'REVERSE POLARITY'
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
