mike-s
Oct 03, 2018Explorer II
theoldwizard1 wrote:Define what you think is the difference between PCM and regulation, and what you thing "the PCM" is, because the normal meaning is that pulse code modulation is a method, not a thing. Also, PWM is very much more common than PCM. PCM requires being able to control the voltage directly, so there's no real advantage to modulating it for a simple battery charging circuit. PWM just basically needs a switch.
On almost all light duty vehicle built in the past 10 years, alternator charging (i.e. output voltage) is controlled by the PCM, NOT the "regulator".
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
