mike-s
Oct 04, 2018Explorer II
JaxDad wrote:See, there's the problem with using undefined acronyms. "PCM" seems to be a Ford/GM term, not some generally accepted industry-wide one. And, in electronics, PCM is usually taken to mean Pulse Code Modulation.
PCM is usually taken to mean Powertrain Control Module.
My car uses an ECM (Electronic Control Module) to sense the battery. That info goes to an IPDM E/R (Intelligent Power Distribution Module Engine Room), which in turn controls an IC (Integrated Circuit) regulator using PWM (Pulse Width Modulation).
No PCM to be found anywhere, but there is a regulator.
