marcsbigfoot20b
Oct 05, 2018Explorer
shane102.sc wrote:
jax mike-s marcs and red 31 stop scuffling over acronyms and Capitol letter abbreviations and put that thinking into solving my issue.
Come on boys. start at my first post and read all the posts and get to work. (please)
I am now letting the camper sit over night plugged to truck to see if problem is solved. basically all I have done is checked for draws and have found none on the truck side and/or camper side. cleaned a few connectors and thats it.
We will see in the mourning if batteries stay charged
Thanks for the help
Shane
So a recap please.....
I think you were saying that by itself, the travel trailer voltage holds its own, mostly.
If hooked up to the truck, the batteries drain quickly?
If that is correct, you need to verify that your truck 7 pin is wired correctly and the charge relay or charge wire if your truck has one is hooked up correctly.
What truck and trailer model, year?
