theoldwizard1
Oct 09, 2018Explorer II
marcsbigfoot20b27 wrote:
For the RVC system like on my 13 Tahoe, you can simply disconnect the amperage sensor around the positive wire and it will be steady and not in different charge modes.
If you read into it, there is a lot of thinking going on by the BCM for battery charging, even "desulfation mode".
I can view and change the output of the BCM commanded alternator output volts and amps with my Tech 2 and see if everything is working.
Most "smart charging system" have the "smarts" in the PCM/ECM/ECU. (Pick one acronym - they all have the same primary function. Control the engine for better fuel economy and emissions.)
Why ? Because the PCM CAN raise the idle speed to accommodate the vehicle requirement for more voltage from the alternator/regulator.
What we call the "regulator" these days has less functionality than in the past. Someone tells the regulator to "make more voltage". The alternator does so (by changing the current going to the field) and then reports back "I am making X power". That report might be a percentage, or a voltage, depends on the manufacturer. While these messages could be passed on some kind of "data bus", they frequently are passed using pulse width modulation on dedicated wires.
You can have very weird charging systems problems when one of those computers is "lying" (passing invalid information) to the other.
