p220sigman wrote:
My plan right now is to get as powerful one as I can afford and put in a transfer switch to run most/all of the house with maybe the exception of the heat pump. We are on a well, so it is critical that I be able to run that.
If you are on a well, you will need at least a 5000W (240VAC) generator. Running one of those on a 20lb
(4.7 gallons) BBQ tank is a joke ! 100lb should last 24-48 hours depending on how much power you are using.
Forget running the heat pump ! Buy a tank, at least 150
gallons, and bury it.
Also, you don't want a "transfer switch". You want a generator interlock. Cheaper, easier to install and easier to use.
If your electrician doesn't know what that is, hire a different electrician. If you tries to sell you the transfer switch, he is just trying to make more money.
Without the tank, you can easily meet your budget,
