We live in Central FL. Hurricanes and tropical storms are all too common here.
For years, I've used a Yamaha EF2400iS to power our travel trailer while boondocking, and run essential equipment at the house when the grid goes down.
A couple of years ago, we added a Champion 7500W dual fuel generator. I also added a 10 circuit transfer switch to our home. Now powering essential equipment is a flip of a switch.
Here are details of the transfer switch installation (DIY):
http://www.2manytoyz.com/manualtransfersw.html
Most people are aware that stored gasoline degrades over time, even with additives. Propane doesn't. My plan of use is to run the generator on the two 100 lb propane tanks that were purchased just for this reason, then move to the multiple 20 lb tanks we have. All else fails, we'll run it on gas, and thoroughly drain the carb and bowl after the storm has passed.
A quick overview of how I'm using the large tanks with the generator, and how I change the oil on this heavy machine:
https://youtu.be/wM_mMlQsOuMHere's how I added a 15' propane hose, with a quick-disconnect, to the generator:
https://youtu.be/XLCl4qDagBgSources of parts:
Brass fittings: https://gashosesandregulators.com/
15 foot propane hose: https://amzn.to/2PiPEe0
Propane quick disconnect: https://amzn.to/2IuKBqn
Teflon tape: https://amzn.to/2GhxXHF
Pipe thread sealant: https://amzn.to/2GqrGKR
Champion 7500W Dual Fuel Generator: https://amzn.to/2UDPGTz
Champion generator cover: https://amzn.to/2XjZCOV
Propane Tank Adapters - LP Tank POL Service Valve: https://amzn.to/2DjJ6qu
Worthington 100-Pound Steel Propane Cylinder: https://amzn.to/2VPP2yG
VELCRO Brand - ONE-WRAP Roll, Double-Sided: https://amzn.to/2Xk0Mdf
Creality CR-10S 3D Printer: https://amzn.to/2XhzTXq
Propane Tank Cap - Free 3D design: https://www.thingiverse.com/thing:1621938
Won't be long before hurricane season is here once again!
