Ramblin__RalphExplorerJun 27, 2019Dump valve won't close all the wayMy black tank dump valve suddenly started not closing all the way. About 1/4" left to go on the shaft. I tried opening and closing it several times, but no luck. I'm guessing maybe TP is stuck in t...Show More
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
Related ContentLasalle Bristol dump valves jammed closedGrey Tank Valve Stuck ClosedBlack Water Valve Will Not CloseHelp - Propane valve stuck closedBlack Tank flush with valve closed
