DFord
Jun 27, 2019Explorer
I had the same problem awhile back. I opened the valve and flushed several times before disassembling the valve to find out why it wouldn't close. I found the disk from the hole the builders cut into the tank for the toilet jammed in the valve. There's no way for it to pass through the dump valve - it could only be removed by taking the valve apart.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
