Bill_Satellite
Jun 28, 2019Explorer II
Since the valve is already open the tank should now be empty. Try to tilt the RV the opposite direction of the valve to move any remaining liquid away. Only 4 screws hold the valve in place and should be fairly easily accessible. Remove the valve and keep an eye on the 2 seals on each side. Remove the TP likely built up in the opening, clean and re-install. If it's anything internal (unlikely) you just buy and install a new one.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
