cbwallace
Jun 28, 2019Explorer
ken56 wrote:
Pick up an add on valve. It will attach just like the hose and you will not need to take a shower after taking off the cap. Just use gloves and a bucket to catch the black water that has seeped past, attach the temporary valve and go. Its a temporary fix until you can repair the one that is supposed to work. Any camping supply store should have one.
My new FW had a grey tank valve that would not close all the way. I picked up an add on valve to avoid a shower when trying to dump. After using the add on valve 1 time there was enough water in the holding tank to free whatever was causing it to stick. May not be as lucky with a black tank but certainly does not hurt to try.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
