Ramblin__Ralph
Jun 28, 2019Explorer
Many thanks for the ideas! The add-on valve sounds like a good solution. However, I'm a bit concerned about the added length. I have a 2WD truck camper and sometimes get on dirt roads with potholes.
No way would I try to change the valve. It's in a rear compartment behind PVC plumbing drain lines and I'm nearing 80. :)
I did add years ago a garden hose fitting, with a valve, to the end of the dump pipe. However, it appears to be frozen. Will try a new one as a "first fix".
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
