Ivylog
Jun 16, 2016Explorer III
As usual Doug knows his stuff. Since you have a 5 button Tstat and it's defaulted to heat it's a old style unit (like mine) and the control board is 3109229.009.
I would try a Tstat reset although it sounds like a control board:
SYSTEM RESET
a. Turn the ON/OFF switch to (OFF) position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to (ON).
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released signalling proper
communication between the Tstat and upper control
board.
If you do not get FF then I would try cleaning the contacts on the phone plugs that connect the Tstat and control board.
$125 on Ebay.
SYSTEM RESET
board.
$125 on Ebay.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
