dougrainer
Jun 16, 2016Nomad
howardwheeler wrote:
It worked!!The reset on the thermostat brought everything back to normal! Thank you all. It's in the high nineties, so hopefully you can feel my appreciation. It is really strange what happened, though. The compressor alone would run anytime power was to the unit, regardless of what the thermostat was set on, including completely off!
The reset did not fix it. The relay just opened. ALL a reset does is verify the DIP switch settings. THAT IS ALL A RESET DOES. Nothing else. It will fail again. For some reason, people think the Dometic CCC tstats are like a computer and a reset fixes operational problems. It does NOT. What you have is a PENGUIN model that comes with a new control board. But that board is a 12 button CCC board. They installed a 12 to 5 button kit to work with the 5 button CCC tstat. IF you have just one roof top unit, you do NOT install the 12 to 5 kit. You purchase and install the 12 button wall tstat which is about the same price. If you have more than 1 roof AC unit, then you have to purchase the 12 to 5 kit so the other AC units can communicate. Doug
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
