howardwheelerExplorerJun 16, 2016Duo Therm Heat Pump weirded outI have a less than two year old Duo Therm Heat Pump that has suddenly started having the compressor run anytime 120 volts is to the unit. Only if I shut off the breaker will the compressor stop runnin...Show More
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
Related ContentDuo Therm Heat/AC function questionWeird sounds at nightdometic duo therm a/c heat pumpWeird question/weird dogOutdoor Griddle Heat Issue
