dougrainer
Mar 20, 2017Nomad
dsikes8 wrote:
We waited about 15 minutes. When the fan did run the compressor never kicked in. I am thinking it is best to replace the unit. I am fairly handy and would like to tackle this myself. Would there be a benefit of upgrading to a 15,000 btu system? Which model would you all recommend. Thanks for the advice so far.
You may have 2 problems. Or just 1 problem. The top unit is just that, The top unit. The control box and the wall tstat are separate parts. So, if you have a Tstat/control board problem, a new upper unit will not fix anything. YES, upgrading to the 15k is a good move for what extra dollars they cost. B59146.XX1J0 is the 15k model of your unit. Ducted or non ducted makes no difference on the upper unit. Doug
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
